1993 Ford Probe Rough Vibration
155,191 MILES • 6 CYL • FWD • MANUAL
KFORDMAN22
I have a '93 Ford Probe GT. When I am deccelerating, the car at around 20mph will start to vibrate pretty badly near the pedals and the vibration either slows or gets faster with the speed of the car. It started when we rotated the tires. The vibration goes away around 25-30mph. We replaced the wheel bearing thinking that was it, and didn't help nothing. Also the car will shake when coming to a stop. Hopefully these problems are related and can be fixed by one thing. I would really appreciate the help. Thank you.
Sep 17, 2008 at 2:18 PM
2CARPRO JACK
  • 11,533 POSTS
Try rotating the tires back and see if it goes away, you may have a tire that is seperating or has another problem. Does th esteerring wheel shake when you apply th ebrakes? if so th erotors could be warped if putting the tires back doesnt fix it
Sep 18, 2008 at 1:18 AM
