1993 Ford Probe 4 cylinder 2.0 liter dohc, with front wheel drive and 120,000 miles.
Checking trouble codes with jumper wire i made a mistake and jumper-ed ground to +b terminal . Now when i turn key on the check engine light and cluster lights will not come on .what did i short out and how do i repair . Is there a fuse to change or light bulbs to change on instrument cluster?
Aug 21, 2008 at 11:48 AM
