Cars do become less efficient over time, just a natural occurance from the wear on the engine. Have you changed tire brands? Try checking the tire pressure, most tires nowdays use a 44psi suggested inflation, others are as high as 51psi. Tire underinflation is the#1 cause of mileage loss. Also front/rear end alignment will cause loss of mileage due to excessive tire friction
SPONSORED LINKS
Monday, April 5th, 2010 AT 11:45 AM
