1993 Ford Probe battery drains
148,000 MILES • 6 CYL • FWD • MANUAL
KURTISJOHNSON
hi, my battery will take a charge and hold a charge, but it will drain overnight. i have to disconnect the battery so it dosen't drain. i just bought the car and need to replace the tranny, but the battery draining problem seems to be the bigger issue as far as reliablity. i can't figure out what is draining it. thanks
Sep 8, 2008 at 9:27 AM
BLACKOP555
  • 10,386 POSTS
one thing to do is everynight pull one fuse and see if that stops the drain, if not pull a different one the next day and see.
either that or you can use a voltage tester and discconect one at a time untill you see the voltage stop draining. the last one pulled is the one thats caused it.
Sep 8, 2008 at 11:31 AM
