1990 Ford Probe
TSLAYBACK
  • 1990 FORD PROBE
Heater problem
1990 Ford Probe 4 cyl All Wheel Drive Manual
I want directions on where the thermostat is and how to replace it with directions and a visual picture
Monday, November 2nd, 2009 AT 1:47 AM
Follow the top radiator hose down to the water outlet on the engine; it is in the water outlet.
Drain radiator to below level of thermostat.
Disconnect coolant temperature switch at thermostat housing.
Using pliers, clamp hose clamps, then slide toward center of hose.
Remove upper radiator hose.
Remove two attaching nuts, thermostat housing, thermostat and gasket. Do not pry housing off.
Reverse procedure to install. Tightening to specifications
Sorry no pic available
Monday, November 2nd, 2009 AT 3:41 AM
