1989 Ford Probe
AMARAZ
  • 1989 FORD PROBE
Engine Mechanical problem
1989 Ford Probe 4 cyl Two Wheel Drive Automatic
I'm 17 and I cracked the head on the engine. Someone told me that I got anti freeze in the lower end and I need to replace the engine. Someone else told me that the engine needs to come out the bottom, no room on top, is this true?
Friday, April 11th, 2008 AT 5:19 PM
BLACKOP555
  • 10,371 POSTS
You can fix the head and the vehicle should run fine, doesn't matter if coolant gets into the lower end. It will burn right off.
Take the motor out through the bottom, its safer, and quicker.
Friday, April 11th, 2008 AT 7:30 PM
