Electrical problem
1989 Ford Probe 2.2 cyl Two Wheel Drive Automatic 74000 miles
TAIL LIGHTS ARE NOT FUNCTIONING. BRAKE LIGHTS ARE OKAY AND HEADLIGHTS. TURN SIGNALS WORK BUT NOT THE PARKING LIGHTS.
Friday, March 28th, 2008 AT 12:48 PM
BLACKOP555
MECHANIC
First thing I can tell you to do is to check your fuses, then check to see if the wires are grounding out on chasis also.
SPONSORED LINKS
Friday, March 28th, 2008 AT 8:50 PM
DEWAIN
MEMBER
I HAD ALREADY CHECKED ALL THE FUSES-BULBS BEFORE I WROTE TO YOU YESTERDAY. I HAVE LOOKED FOR LOOSE WIRING. ANY OTHER IDEAS?
IS THERE ANY KIND OF SWITCH SOMEWHERE THAT I CAN BE MISSING?
Saturday, March 29th, 2008 AT 9:22 AM
BLACKOP555
MECHANIC
There may be a relay before the tail light, but that should affect braking again. The headlight switch could be bad.
