1992 Lincoln Town Car Serpentine Belt Breaks
FORD
JBRENT
I have a 92 lincoln towncar, with 182,000 miles that is giving me fits. About a month ago the serpentine belt broke. I thought it was no problem replaced it and then about a week ago the new belt broke. I thought it was a bad belt, but the broken belt had drag marks on it and it was twisted, it appears that it got hung up on a pulley and snapped. All the pulley's except the crankshaft rotate free and easy. The tensioner seems to be plenty tight and gives good resistance when engage to put the belt on. The altenator pulley squeaks and I thought that was the culprate, but I took it off and took it to a very reputable generator shop where they put it under a load and told me that there is no way that it broke the belt. The only other abnormality is that the ps fluid leaks, but the ps pump rotates. I don't know were to go next. Please help.
Dec 19, 2006 at 7:01 AM
CARUNDELL
  • 602 POSTS
[quote:fcc46b7788="jbrent"]I have a 92 lincoln towncar, with 182,000 miles that is giving me fits. About a month ago the serpentine belt broke. I thought it was no problem replaced it and then about a week ago the new belt broke. I thought it was a bad belt, but the broken belt had drag marks on it and it was twisted, it appears that it got hung up on a pulley and snapped. All the pulley's except the crankshaft rotate free and easy. The tensioner seems to be plenty tight and gives good resistance when engage to put the belt on. The altenator pulley squeaks and I thought that was the culprate, but I took it off and took it to a very reputable generator shop where they put it under a load and told me that there is no way that it broke the belt. The only other abnormality is that the ps fluid leaks, but the ps pump rotates. I don't know were to go next. Please help.[/quote:fcc46b7788]
Hey jbrent
This may be a pulley misalignment issue, check to see if all the pulleys are aligned with the crank pulley. Should I assume all the pulleys are in good condition? ie: no chips/cracks or missing peices of the pulley. Let us know
Chris
Dec 19, 2006 at 7:29 AM
JBRENT
Hey jbrent
Chris[/quote]
Hey Chris-
thanks for the response- All of the pulley's are intact and spin freely, I am not sure if the pulley's are aligned properly I will have to check. I also wondered if there was something wrong with the tensioner, but it looks and feels fine to me?
Jason
Dec 20, 2006 at 12:46 AM
Suggested Repair
Check that every accessory pulley is aligned with the crankshaft pulley, and inspect all pulleys for chips, cracks, or missing pieces. If alignment and pulley condition are good, recheck the belt tensioner.
Conversation Summary
The owner of a 1992 Lincoln Town Car with 182,000 miles reported that the serpentine belt broke twice. The second belt had drag marks and was twisted, suggesting it caught on a pulley. Accessory pulleys spun freely, the tensioner felt tight, a shop load-tested the squeaking alternator and cleared it, and the power steering pump leaked but still rotated. The expert advised checking pulley alignment with the crank pulley and inspecting pulleys for damage. The owner confirmed the pulleys were intact and planned to check alignment, while also questioning the tensioner.
