Manual choke on Ford Fiesta 1989
1989 FORD
CAZ123
I have been having problems with using my manual choke on my 1989 Automatic Ford Fiesta 1.1 (67,000miles). It cuts out when I stop at a junction even after a good 10 mins of driving with the choke out. Can you advise? I'm I using the choke incorrectly?
Mar 19, 2007 at 1:37 AM
  • 75,988 POSTS
[quote:a03c47b57d="Caz123"]I have been having problems with using my manual choke on my 1989 Automatic Ford Fiesta 1.1 (67,000miles). It cuts out when I stop at a junction even after a good 10 mins of driving with the choke out. Can you advise? I'm I using the choke incorrectly?[/quote:a03c47b57d]
You must pull it out-and if set correctly give atleast 3 minutes and push it back in. Old school the choke plate should be fully opened in that time.
When its out you're choking it big time Note: The engine needs air just like us.
Mar 19, 2007 at 2:54 AM
MIKEREDBLACK
Your float in your carb could be stuck. Pull it of to see
Mar 20, 2007 at 1:25 PM
MIKE H R
  • 3,094 POSTS
Check the choke cable. sometimes the choke cable sticks making the choke. Also it sounds like there is a gas problem or a stuck float. Check the idle adjustment.
Aug 17, 2015 at 11:37 AM
