1987 Ford Cougar Fuel Pump Not Running
FORD
STOLENFAITH
i have a 1987 cougar with 182,000 miles on it i jroped the fuel tank to jb weld it and now there is no fuel runing though anything its not even geting to my fuel filter when i turn my key i can here the realy click but not the fuel pump what might be the problem ? thanks
Mar 14, 2006 at 12:24 AM
PEPPERMRJ
  • 1,158 POSTS
Hate to be the bad news guy but, Sounds like the wiring or connection to the fuel pump is bad.
Good luck and let us know. :)
Mar 14, 2006 at 1:11 PM
PEPPERMRJ
  • 1,158 POSTS
Whenever you pull a tank and then reinstall it you run the risk of pinching a wire.
The first place I would start is with the fuses. Are they intact?
If not replace and see if they solve the problem or they blow again.
If they blow you have a short somewhere. I always look at the last thing I touched. In other words pull the tank again and look closely at the wiring.
If the fuses and relays are good but still no pumping you need to follow the wiring back to the pump. A wiring diagram is a must.
Good luck. :) :)
Mar 15, 2006 at 7:29 AM
NOS
  • 320 POSTS
it sounds like you have done one of three things lost your power to the pump by pinching a wire,two you have pinched the fuel lines .and thre you may have triggered the enerita switch which will shut the system down it is most time in the trunck if not there look in owners manual for locating of it. by jacking the car up you may have triggered it to off it is a red button locate it and push down in it to make sure it is on. hope this helps ( NOS )
Mar 15, 2006 at 12:24 PM
PEPPERMRJ
  • 1,158 POSTS
If your fuel pump is now working and the engine will run with fuel added to the throttle body you need to check that fuel injectors are firing.
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
Good hunting. :)
Mar 23, 2006 at 12:11 PM
Suggested Repair
After the fuel tank was dropped and reinstalled, check the fuses first. Replace any blown fuse and see if it blows again, which would indicate a short. Inspect the tank wiring and fuel lines for pinching. Reset the inertia switch, usually a red button in the trunk (confirm the location in the owner's manual), by pressing it down. If the fuses, relay, and inertia switch are good but the pump still does not run, trace the wiring back to the pump using a wiring diagram. If the pump later runs and the engine will run with fuel added at the throttle body, check whether the fuel injectors are firing.
Conversation Summary
The owner of a 1987 Ford Cougar with 182,000 miles dropped the fuel tank to seal it with JB Weld. After reinstalling it, no fuel reaches the filter or the rest of the system. The relay clicks when the key is turned, but the fuel pump does not run. Experts advised checking fuses for a short, inspecting for pinched wires or fuel lines from the tank work, resetting the inertia switch, and tracing the pump wiring with a diagram. If the pump later works, they also suggested verifying that the injectors are firing.
