ford ka
FORD
CARLSMITH
my front and rear side lights and instrument lights are not working the fuse is ok they are all on same circuit any ideas :cry:
Nov 19, 2006 at 12:56 AM
BAREFOOTBOB88
  • 60 POSTS
Its pry something real small and stupid. The only thing I think that could be the real culpret is a bad ground. Fords are really hard on the electrical grounds. I have no clue how old your car is but if it's like 10 years or older then you pry have a bad ground. There is no good way to test for this kind of thing. If you could get a wiring diagram of your car you'd pry have better luck finding where the ground is for that circut. A ohm/volt meter would be handy also.
Nov 19, 2006 at 3:45 AM
