If the motor home sat for any leanth of time there could be a build up of what they call varnish, it comes from gas sitting for a long time and going bad. You will be able to tell if you remove the gas cap and smell it. Run some fuel system cleaner in it. If you are not using it for a while then add fuel stabilizer. Gas starts to break down after a couple of months. Another reason you might be having this problem is that sometimes when a vehicle sits water vapor gets in the tank. That would be another reason why it runs for a while then stops. Have it checked to see if water is in the tank.
Where I used to work we had a car come in, the fuel guage said it had over half a tank. We found out that it had more than half a tank of water.
SPONSORED LINKS
Thursday, December 18th, 2008 AT 2:57 PM
