1987 Other Ford Models ENGINE NOT RUNNING SMOTHLY WHEN STOPP
1987 FORD
187,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAUMYA
When car is stopped and gear is engaged then the engine does not run smothly. when the gear is shifted to neutral possition it is running smothly. I do not know whether it is a problem of carburetor or engining tunning. I have replace all four plugs but did not make any different. thank you
Mar 30, 2008 at 9:23 PM
  • CERTIFIED EXPERT
Check the engine compression if its on specs give it a major tune-up continues comeback there's a lot that can make the engine not to run smoothly-such as fuel pressure/vacuum leak and so on-
Mar 30, 2008 at 10:21 PM
