HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Other
Engine
Symptoms
Stall While Driving
1982 Other Ford Models stalls
MOONSHINER
MEMBER
1982 FORD
6 CYL
2WD
MANUAL
110,000 MILES
Engine trys to stall when comming to a stop
Monday, April 28th, 2008 AT 10:45 PM
ROB2008
MECHANIC
Sound like it COULD be a vacuum leak look around the hoses and listen for a hissing noise.. Or if this only happens when you hit the brake it might be a brake booster. The fords an 1982 so you might not have a brake booster. Check the idle also
SPONSORED LINKS
Monday, April 28th, 2008 AT 11:06 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
1986 Ford Will Not Stay Running
I Have A 1986 Ford Family Wagon With 13,000 Original Miles. It Has Always Started And Ran Great. I Hadn't Started It For Awhile And Needed...
Asked by
creampuffy
1986
FORD OTHER
VIDEO
How to Read Codes
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
Car Stalls When Put Into Gear
When I Start The Van It Starts Up No Problem. But When I Shift It Into Gear It Stalls Out. I Already Replaced The Solenoid In The Tranny....
Asked by
Iwahahdamnsn
1999
FORD OTHER
Vapor Lock I Think
I Have A 1981 F100 2wd Automatic 302 2 Barrel. It Seems To Vapor Lock. I Will Be Driving It Then It Just Doesn't Get Gas To The Fuel Filter...
Asked by
tumbleweed
FORD OTHER
Engine Dies Not Long After Acceleration(when Hot)
Ford Telstar 1988 2l. From A Cold Start, Never A Problem. But When Car Hot -. E.G. Drive One Hour, Then Stop Car For Short Time. Then...
Asked by
justwantmycarfixed
1 ANSWER
FORD OTHER
1986 Ford Engine Stalls/bucks At High Rpm
I Have A 1986 Ford Bronco Ii. 2.9l. It Stalls At High Rpm. Changed Fuel Fliter, Checked Fuel Pumps, 40 Psi On Fuel Rail Koeo, Drops To...
Asked by
Jerry Gman
1986
FORD OTHER
VIEW MORE
SPONSORED LINKS
How to Read Codes
How to Read Trouble Codes
Code Read Retrieval/Clear - Dodge Stratus
Online car repair manuals
