1960 Other Ford Models radio noise
1960 FORD
18,525 MILES • V8 • 2WD • AUTOMATIC
TKARSTS
  • 5 POSTS
hi i have a 1939 ford street rod with a ford v8 gm alt. i have tryed resistors suppresser different plug wires. i've several different rod and no problems with them ! I;ve replace the alt and takeen of the wire to the alt and the noise goes away any ideas ? help!!!! thanks
Aug 24, 2009 at 11:17 AM
HMAC300
  • 48,601 POSTS
you may need to put a resistor/condensor on the alternator to eliminate the noise. Also if you can and have a modern radio in your car. That will help as well.put a ground wire between the frame and engine and body and engine Your other post didn't say it was a one wire connection. What you have is an alternator noise from the voltage being put out. Try finding a electronic / electrical engineer around you they should know how to get rid of it. If this is a glass rod, you'll need a ground wire to the dash or radio.
Sep 29, 2009 at 11:03 AM
