Pinging - Detonation
DSTRYKER24
  • FORD MUSTANG
I have a 2000 Mustang GT with 122,000 miles. At 4,000 RPM's I am getting a bad pinging (detonation). Does not matter if I am at WOT or not. It has been doing this for some time now.
So far I have replaced the computer, fuel pump, MAF Senso, cleaned my K&N Air Intake, have ran some Injector Cleaner through it and I only run Supreme (91 here in AZ & I have tried adding Octane Boost).
Also, when the A/C is running idle sits at 750rpm's, jumps to 1,100 and settles back down to 750.
Any thoughts or reccomendations?
Friday, March 3rd, 2006 AT 6:20 PM
NATHAN
  • 5 POSTS
Your timing may be off. A throttle position sensor might fix the idle problem. I believe the stock timing for mustangs is 10 degrees ( I own a 92 5.0 and thats the stock timing for it)
Saturday, March 4th, 2006 AT 4:18 AM
XJETMECH
  • 12 POSTS
Could be a bad knock sensor. It's supposed to retard the spark a little when it senses a knock.
The idle rpm may just rise and fall as the A/C compressor cycles.
Tuesday, March 14th, 2006 AT 12:41 PM
