1967 Ford Mustang Excessive Oil Use
There is only two ways the engine will use oil, burning & external leak. You say there is no external leak so you must be burning oil. Check the spark plugs, are there any deposits building up on them? Does is puff a little blue smoke on start up? This would be valve stem seals or worn valve guides. You say the comps are ok, but that won't give a good indication as to the condition of the oil control rings. Do a consumption test, This is best done with fresh oil and a new filter. Change oil and filter, have oil level spot on the mark. note speedo, in one week of normal driving re chek oil and add if required, but messure excatly the amount added, use a plastic kitchen mesuring jug. note speedo and you will have oil usage per miles/ Km's If plugs are fouled don't bother with a fix in a bottle, waste of time and money re buid as required will be the only answer. Depending on the type of oil you would not want to be using any more than 1/2 Litre per 5,000 Km's (sorry not on Miles and gallons in Aust)
Do the test first, good luck
Mark (mhpautos)
Suggested Repair
Measure oil use over a week of normal driving with fresh oil, a new filter, and the level set exactly on the mark. Inspect spark plugs for deposits and note any blue smoke on startup, which can indicate worn valve guides. Compression does not show oil-ring condition; if plugs are fouled or consumption is high, plan a rebuild rather than using an oil additive.
Conversation Summary
The owner of a 1967 Ford Mustang 289 reports excessive oil use with no external leaks, replaced valve stem seals, steady vacuum around 20.5 inHg, and compression from 137 to 161 psi, but no visible exhaust smoke. The expert says the oil must be burning and recommends checking the plugs and startup smoke, then measuring consumption accurately. High use or fouled plugs points to worn oil-control rings or guides and a rebuild rather than a bottle additive.
