Clutch Pedal
ZANIUSMAXIMUS
  • FORD MUSTANG
2000 Mustang 3.8 V6
Clutch pedal is on the floor and will not come back up. After running at 3000 rpm for 30 minutes it will finally come back up. It can be shifted if the clutch is barely depressed. Extremely hard to drive this way.
Clutch was replaced 2000 miles ago total miles 99300
Wednesday, May 16th, 2007 AT 8:34 PM
MIKE H R
  • 3,094 POSTS
I believe you have a hydrolic clutch, check the fluid level, also check the cluch slave cylinder to see if it is leaking and working properly.
Thursday, May 17th, 2007 AT 8:15 AM
Related General Content
