A very hot Pony
TLMILLO
  • FORD MUSTANG
My daughter has a 95 base mustang, it has started to overheat, but only with the a/c on. I also noticed that the fan is not coming on when the alc is on. The car overheats to a point that I guess the computer shuts off the compressor and it blows warm air. After the vehicle cools down the a/c blows cold until it overheats again. I have replaced the cooling fan, coolent sensor, radiator, thermostat, and new anti-freeze. Any ideas, on what the problem could be? [She will be taking this vehicle to college ] thanks, Larry
Wednesday, June 20th, 2007 AT 8:01 PM
TLMILLO
GOOD DAY!Checked all fuses under hood, all ok. Any ideas on where to go from here. Thanks Larry
Thursday, June 21st, 2007 AT 5:28 PM
TLMILLO
Checked all the fuses in the box under the hood, as you instructed, they are all good. The radiator fan works normally cycling as needed until the a/c is turned on then it doesnt work, engine gets so hot that the a/c compressor shuts off and blows warm air, now if you stop the car and let everything cool down, a/c works fine until car starts to overheat and compressor turns off again, any ideas on what else to check. Thanks, Larry
Thursday, June 21st, 2007 AT 8:25 PM
TLMILLO
I installed a new radiator, and fan. However when a/c is on--- cooling fan does not come on at all.
Thursday, June 21st, 2007 AT 11:26 PM
Related General Content
