2005 Ford Mustang vacuum leak
35,000 MILES • 6 CYL • FWD • AUTOMATIC
RAMAN6923
the check engine light came on, after checking I could distinctly hear a hissing noise. I'm told that is the sound of a vacuum leak. I need to know how to find it first, any directions on this would be very helpful. Thank you!
Nov 29, 2008 at 3:39 AM
  • 75,988 POSTS
Something caused that CEL to come on-could lead you to the problem if you scan the computer for OBD2 code/s. To check vacuum leak-use WD-40 and spray between the intake manifold and engine block-throttle body,look around for a disconnected hose and a leaking one-inspect the hose that goes to the brake power booster-when you hit the leak the idle will smooth out-
Nov 29, 2008 at 4:10 AM
RAMAN6923
Thanks!
Nov 29, 2008 at 7:45 AM
