2002 Ford Mustang oil change
ANZAKID
  • 2002 FORD MUSTANG
  • 6 CYL
  • 56,000 MILES
I have been haveing my motor and auto transmission
oil changed at a quick change place. I noticed that they do not remove the driain plug from either location. After some thought on the subject I don't think I will return. Am I wrong?
Thursday, January 22nd, 2009 AT 7:53 PM
OBXAUTOMEDIC
  • 3,711 POSTS
To begin with how often are you having your Tranny Fluid changed. It is probably not recommended for another 35k or so miles. And most Transmissions do not have a Drain Plug. You remove the Tranny Pan to drain.
Now, the Oil - If you feel that the oil isn't being change all you have to do is pull the dip stick and the oil should be a clear carmel. Unless you have driven it for a few days or more, then it should be kinda see through gray.
If you would like to change your own oil and filter check out the link below.....
https://www.2carpros.com/how_to/how_to_change_oil_filter.htm
Thursday, January 22nd, 2009 AT 8:04 PM
