2000 Ford Mustang Smell of Anti-freeze when I turn on the h
2000 FORD MUSTANG
RSARNECKY
Heater problem
2000 Ford Mustang 6 cyl Wheel Drive Type unknown Automatic 88495 miles
Lately, I have been smelling anti-freeze when I turn on the heater, and the coolant was down to zero, even after I refilled it. I took my car to the mechanic, who confirmed that coolant was pouring out of the lower intake manifold gasket. They replaced the Intake Manifold Gasket, T-Stat, and thermostat Gasket . Plus, they flushed the cooling sysytem. However, while the car no longer reeks of the anti-freeze smell, I can still smell anti-freeze when I turn on the heater. Can anyone help me?
Dec 19, 2007 at 10:09 AM
BLACKOP555
  • 10,386 POSTS
is their condensation appearing on your window? a little bit may leak out of the heater core hoses causing the smell or the cabin air filter could be saturatred with coolant.
Dec 19, 2007 at 11:44 AM
RSARNECKY
No. That's the weird thing. There is no moisture anywhere. No condensation.
Dec 20, 2007 at 12:48 AM
BLACKOP555
  • 10,386 POSTS
change your cabin air filter, and also mix bleach in hot water and remove the blower motor and spray it in the ducts and turn it on.
Dec 20, 2007 at 6:26 AM
