1999 Ford Mustang battery
FGOMEZ23
  • 1999 FORD MUSTANG
  • 6 CYL
  • MANUAL
  • 122,000 MILES
I recently bought a battery n accidently put the battery backwards which blewout my fuse that controls the radio and now the radio works but my battery goes dead if I dont move for a day or two
Wednesday, August 6th, 2008 AT 10:49 AM
DOCFIXIT
  • 18,828 POSTS
You may have fried a diode in alt. With key off pull battery cablr get a spark? If so something is drawing power. Now remove red batt cable from back of alt. Does spark go away from batt cable? If so alt is problem. If this all fails you need to have a battery drain test done to determine source of drain.
Wednesday, August 6th, 2008 AT 11:11 AM
FGOMEZ23
I did what you ask me to do I disconnected the red cable of the battery then took the cable of the alternator off and the red cable of the battery still gave a spark so I know now that it isnt the alternator do you know if maybe one of the fuses burned out.
Wednesday, August 6th, 2008 AT 12:45 PM
DOCFIXIT
  • 18,828 POSTS
You need to have a battery drain test down to pin point circuirt that is at falt. You have about a mile of wire in car and hundreds of components this test will find the problem. Otherwise your fighting windmills
Thursday, August 7th, 2008 AT 11:45 AM
