Just had new clutch by an individual, used a complete cutch kit.
Now clutch is slipping slightly, and mechanic says that there is no adjustment.
is there has to be somewhere to adjust?
Thursday, June 18th, 2009 AT 11:01 AM
DOCFIXIT
MECHANIC
Hi
No adjustment automatic self adjuster on pedal. Will trans go into gear? Was old clutch slipping?
Was flywheel turned?
Let me know
Thanks foe donate
SPONSORED LINKS
Thursday, June 18th, 2009 AT 12:28 PM
MGMMARK
MEMBER
No, flywheel was not turned, clutch was not slipping before.
It will go into gear and drive fine as long as not to much on gas. If you put your foot into it, then it will slip.
Thursday, June 18th, 2009 AT 1:01 PM
DOCFIXIT
MECHANIC
Pressure plate issue. Is there any pedal freeplay?
Think your going to need to tear it down again.
Thursday, June 18th, 2009 AT 1:21 PM
MGMMARK
MEMBER
No freeplay at all, clutch doesn't fully disengage until very top, hey, guess thats the trouble, its not fully disengaged at the top!
Can you elablorate on pressure plate issue so I can make sure its right this time?
Thursday, June 18th, 2009 AT 4:12 PM
DOCFIXIT
MECHANIC
The throwout bearing may have been installed in correctly keeping pressure on pressure plate. Remove cable from fork is there free play in fork?
