I have a battery sitting at 13.5 volts using a battery tester that plugs into the cigarette lighter. The accessory lights work when the key is turned to accessory. As soon as I turn the ignition, however, the battery shows zero charge. If I disconnect and reconnect the battery, the accessory lights come back on. The car will only crank when being boosted by another car that is running. It runs perfectly after being boosted. The second I turn the car off after removing the booster cables, however, it will not turn back on. Any ideas?
SPONSORED LINKS
Monday, May 12th, 2008 AT 9:08 PM
