1996 Ford Mustang Would like info
1996 FORD MUSTANG
54,000 MILES • V8 • 2WD • MANUAL
KETCHERJL
Hi, i have gone over your website under how it works but I still have questions. I just bought a 96 mustang in October it is curantly in storage, but any way it has a lot of after market parts in it i was told about $15,000 worth. And i am mechanically handcapped and don't know what it all does, and i would like to know what all these parts do for my car, so if you would be willing i will give a list if you could tell me what they do that would be awsome.
3 core aluminum radiator, msd ignition,36lbs
fuel injectors, bbk adjustable fuel pressure regulator, cervinis ram air hood, lowering springs, bassani x-pipe w/cats, cat back exhaust,rear end gears, Diablo chip, procharger p1-s supercharger w/intercooler,
weld in subframe.
Feb 4, 2008 at 6:47 AM
MASTERTECHTIM
  • 4,750 POSTS
holy crap, thats alot of extras. first of all a 3 core radiator just means your cars radiator is bigger than the factory one, thus keeping engine in the temp range with all of the extra horsepower you have added. msd ignition is a high performance ignition system to give you more powerful spark to your spark plugs. 36 lb injectors have a bigger bore in them so when the computer holds them open longer it will allow more fuel to enter the intake. the adjustable regulator lets your fuel system maintain a higher fuel pressure. lowering springs are exactly that, they are shorter coil springs for your suspension. supercharger forces air into engine giving you more horsepower. x pipe is a part of the exhaust that evens out back pressure to let vehicle exhale smoother. hope this sheds some light
Feb 4, 2008 at 7:06 AM
