Saturday, September 26th, 2009 AT 9:08 AM
When I start up it putts like I have it in too high a gear. I had Auto Zone check and the page reads: evap canister purge valve mechanical fault or vmu fault condition. Explanation ecm detected a fuel tank pressure change greater than a minus 7 inches of h2o in 30 seconds with purge less than o.O2 lbs per minute Probable cause 1. Failed evap pressure sensor 2. Blocked hose between purge valve and ftp sensor 3. Evap purge valve stuck closed Will this be the problem, or is this just a second problem also. And can I get this parts at a part or do I have to go to Ford? Thank you! Debbee
