Code showing random misfire and cylinder#2misfire. Fuel burning smell. I changed sparkplugs, coil, injector #2. Same problem.
Wednesday, November 4th, 2009 AT 5:58 PM
MECHANIC
Check compression on no.2 and also check the items below
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
SPONSORED LINKS
Wednesday, November 4th, 2009 AT 6:10 PM
SAMMMM
MEMBER
I did compration test.150 to 170.I changed plugs, coil. Injector#2. Putinjector cleaner. Fultank fuel. Still same problem.
