1990 Ford Mustang Power Drain
1990 FORD MUSTANG
14,900 MILES • V8 • 2WD • MANUAL
JOEY@NSCN.COM
  • 7 POSTS
I have a 1990 5.0 And all of a sudden my battery amps are low. I replaced the battery. which didn't help. So I took my alternator and had it tested. It was good. I don't know what is draining my amps
Jan 13, 2009 at 10:53 AM
DOCFIXIT
  • CERTIFIED EXPERT
  • 18,828 POSTS
Most likely some circuit is powerd up with key off. Try disconnect batt overnight if this helps . then you need a battery drain test done to find circuit and repair.
Jan 13, 2009 at 11:16 AM
JOEY@NSCN.COM
  • 7 POSTS
When I took it to have a power test it shut my car down and now it wont start. I have no power to my fuel pump or power windows. But my lights work and CD player.But it wont start.. So I replaced the starter relay and checked my fuses .. still nothing
Jan 19, 2009 at 5:23 PM
DOCFIXIT
  • CERTIFIED EXPERT
  • 18,828 POSTS
What was power test? It died during test? There are fuse links on your car looks like wire. Near starter relay use test light find A Brown link it may have been blown. it is for fuel pump. Then check fuse # 14 for power windows.
Jan 21, 2009 at 4:10 PM
JOEY@NSCN.COM
  • 7 POSTS
I checked all my fuses. but i will check the fuse links. But i tried to start my car again and when i put the key in and turned it I had no power. Not to my gauges fuel pump , nothing. So when i tried to turn it over it didn't start but i tried to turn my it over with out pressing the clutch and my fuel pump kicked on. So I'm confused But it still didnt start
Jan 22, 2009 at 12:56 PM
JOEY@NSCN.COM
  • 7 POSTS
So now the car starts, it was my ignition. But i still have no volts.. Again new battery and alternator. Every time i put in a new battery and alternator i will drive it and it will show like 11 volts on my gauge then the alternator will fry.. Something is shorting out or something is busted somewhere. I just dont know were. Please help
Feb 10, 2009 at 3:24 PM
