Your right on all points of your question, as far as the cranking, it could be both, starter or ignition, try to get yourself a cheap remote starter. Or I know there are other ways to get the starter to crank but I cant recommend that. But if you can do it with either the remote start or the other way, that will tell you if your starter is sticking or your ignition is sticking
SPONSORED LINKS
Tuesday, May 6th, 2008 AT 11:14 AM
