1989 Ford Mustang Hesitates
JOEBOX
  • 1989 FORD MUSTANG
  • V8
  • MANUAL
  • 300,000 MILES
How are you doing Sir or Ma'am, I currently been having a problem with my mustang hesitating when I take off in all the gears I go through. I noticed it only happens when the car is cold or not warmed up yet. If I let it warm up it does not do it, if I fire it up and take off within 5 min it will almost stall on me when I am giving it gas, in all the gears. It just starting happening, and I take care of her on a regular basis. Tune up, oil changes everything.
Wednesday, March 10th, 2010 AT 4:44 PM
If the clutch is not slipping. Inspect and test all the following listed below and get back with some testing results we start here
Oxygen sensors.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Wednesday, March 10th, 2010 AT 5:11 PM
