Electrical problem
1988 Ford Mustang V8 Two Wheel Drive Manual 110.00 miles
replaced with new dist new coil its geting power to coil power to dist it is computer controled no now loss wires no fire
Monday, December 8th, 2008 AT 9:31 AM
RACEFAN966
MECHANIC
Have you checked the distributor module? I see you put in new dist. And coil but did the dist. Come with a new module? IF not and you have no spark that is where I would look first. Let me know and we will go from there.
SPONSORED LINKS
Monday, December 8th, 2008 AT 12:21 PM
PEEWEE.V
MEMBER
I put a new module in it still no fire
Tuesday, December 9th, 2008 AT 5:17 AM
RACEFAN966
MECHANIC
Let me know what the voltage is at the poss side of coil and the at the neg side and we will go from there. If this checks out ok then we will go to the module and check to see if power there is going to the right places.
Tuesday, December 9th, 2008 AT 10:03 AM
PEEWEE.V
MEMBER
Just noticed that the feul pump is not working checked reset button no power to button is there a relay that powers this @where is it
Wednesday, December 10th, 2008 AT 5:27 AM
RACEFAN966
MECHANIC
Ok you will never believe this one the fuel pump relay is said to be under the drivers seat. Here is a pic of it so you know what it looks like too. Let me know how this goes ok.
SPONSORED LINKS
Wednesday, December 10th, 2008 AT 10:49 AM
PEEWEE.V
MEMBER
Replaced relay at computer fixed problem in r-side kick panel relay sounded lik it was working clickedever time power up but was no no good cranks and runs fine now
Sunday, December 14th, 2008 AT 8:14 AM
RACEFAN966
MECHANIC
So if I understand right it is fixed? That is great if there is anything else just ask. Have a great day.
