1988 Ford Mustang Engine loads up
LAGNAF
  • 1988 FORD MUSTANG
Engine Performance problem
1988 Ford Mustang V8 Two Wheel Drive Manual? Miles
When I start it up cold it loads up bad black smoke out the pipes when it warms up to around 180 it runs ok I got a Equus 3145 code reader it gave me codes 22, 67.81.82.85 I have replaced the temp sensor changed the Ait Idel Solenoid no good can you please help me its driveing me crazy plus I know if it keeps up it will wash out my rings and the engines gone I am retired and dont lots of money to throw at it.
Thanks
James Skinner
Friday, August 13th, 2010 AT 11:09 PM
Probable causes of an engine running rich are as follows:
1. Excessive fuel pressure can be cause by restricted fuel return line or defective fuel pressure regulator.
2. Defective Oxygen Sensors.
3. Leaking injectors and fuel pressure regulator.
4. Coolant temperature sensor out of calibration.
5. Restricted air intake system.
Saturday, August 14th, 2010 AT 4:10 AM
