1988 Ford Mustang Draining Battery
VANWALKER
  • 1988 FORD MUSTANG
  • V8
  • MANUAL
  • 205,000 MILES
I had to replacethe ignition switch because the old switch had begun to fall apart and the car would cut off during normal operation. As soon as I replaced the new switch my battery began to drain overnight and I noticed that the voltage meter warning light is on and the meter is reading as much as 18 amps during normal operation. I have not yet begun pulling fuses and using a test light or ammeter to check for the source of the drain. One thing unusual is that when I remove the positive battery caple while the vehicle is running the windshield wipers begin to operate on their own.
Wednesday, May 14th, 2008 AT 10:28 AM
MERLIN2021
  • 17,250 POSTS
First, this isn't your grandfathers Oldsmobile, not a good idea to disconnect cables on a running motor nowadays, when you do remove cables always remove the (_) first and put it back on last! Second, check the battery's age and the regulator for the overcharge problem. This may solve all your troubles.
Wednesday, May 14th, 2008 AT 2:11 PM
