1986 Ford Mustang radiatot fluid bloing back into resivor
RONSR2207
  • 1986 FORD MUSTANG
  • 6 CYL
  • 10,000 MILES
Fluid from rad bubbling back into res, installed new rad, thermostat, flused sys, still have same prob. It started to overheat after a/c was serviced. Whats next?
Friday, July 25th, 2008 AT 8:51 AM
DOCFIXIT
  • 18,828 POSTS
With cap off running do you see bubbles?
How is fan operation?
Let us know
Friday, July 25th, 2008 AT 9:06 AM
RONSR2207
[quote="Docfixit"]With cap off running do you see bubbles?
How is fan operation. Still can see bubbles, is head cracked?
Sunday, July 27th, 2008 AT 4:50 PM
DOCFIXIT
  • 18,828 POSTS
More likely failed headgasket. Put a pressure tester on rad pumpup pull plugs. Let set couple hours crank if water comes out plug hole gasket bad.
Monday, July 28th, 2008 AT 8:56 AM
