1986 Ford Mustang idle
DALTO
1986 Ford Mustang V8 Two Wheel Drive Manual
when i start the car it idles fine, after i drive for about 10 to 15 min the idle will go up to about 1200 to 1500, some times it will go as hi as 1800. some times the idle will slow to normal on its own other times i will have to turn the engine off and restart it to get the idle to come down. any sugestions?
Oct 28, 2008 at 3:57 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a sticky Idle Air Control Valve. You can try cleaning it with carb cleaner, it may fix it. If not you will have to replace it. Also check for vacuum leaks, but the IAC sounds like the problem
Nov 12, 2008 at 4:23 AM
MASTERTECHTIM
  • 4,750 POSTS
definitely sounds like a bad iac valve. these are so problematic i would not hesitate to replace, there is a slight chance that it is something else like a sticking tps but its unlikely.
Nov 12, 2008 at 6:42 AM
