I have gas in my oil? I have rebuilt the top end and now there is gas sell in my dip stick. Is this blow by?
Monday, October 20th, 2008 AT 1:27 PM
WHITENOTCH9
MEMBER
1 POST
The same thing happend to me, you need to replace your fuel pressure regulator. And after you change it you also need to change your oil and run it for 15 minuits or so to flush the gas out of your oil system and then change your oil again and then you should be ok
