1985 Ford Mustang fluid under dash
STR8EZ
  • 1985 FORD MUSTANG
Noises problem
1985 Ford Mustang 4 cyl Front Wheel Drive Automatic
I am trying to find out what is making a noise around my panel that sounds like flowing fluid. My car also recently started to get hot even though the fluids are good
Friday, January 16th, 2009 AT 8:19 AM
DAVE H
  • 13,384 POSTS
You may have air in the coolant system. Have the coolant system pressure tested. Have cylinders compression tested. Check for leaks. Check/replace thermostat. You could have the coolant system flushed to clear any blockages !
Friday, January 16th, 2009 AT 8:40 AM
