1998 Ford Mondeo WATER IN STEERING
1998 FORD MONDEO
10TOO3
Steering problem
1998 Ford Mondeo Two Wheel Drive Automatic
Some water was accidently put into the recepticle under the bonnet that holds the steering fluid. Some people have said to me that because it was so little (less than 40ml) that the car would still be safe to drive.
Is this true or false.
Mar 11, 2010 at 12:48 PM
CARADIODOC
  • 34,381 POSTS
It never hurts to flush the power steering fluid and now would be a good time. I wouldn't be too concerned with system operation, but water will promote corrosion of metal parts which can result in seal leakage. This isn't a reason to panic, but it probably shouldn't be ignored.
caradiodoc
Mar 11, 2010 at 1:07 PM
10TOO3
[quote:d9770f63f8="caradiodoc"]It never hurts to flush the power steering fluid and now would be a good time. I wouldn't be too concerned with system operation, but water will promote corrosion of metal parts which can result in seal leakage. This isn't a reason to panic, but it probably shouldn't be ignored.
caradiodoc[/quote:d9770f63f8]
Thank you for your prompt reply.
I probably will drive the car this weekend but will get a mechanic to attend to it as soon as possible.
Mar 11, 2010 at 3:22 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 19, 2010 at 4:42 AM
