2006 Ford Galaxie ABS
2006 FORD GALAXIE
STEPHGOULD
2006 Ford Galaxie Manual
hi my ford fiesta 1.251 onthe dashboard the light comes on saying ABS error so a friend said its you brakes need doing so i bought some and had them fitted but the ABS light is still on do i need a new diogalistical on the car to erase the error message as the braks have been repaird also my speedo wont work it all happend at once is there something called an EBU or something like that also i took the battery off now the radio is not working and i do noe have the code how do i go about that
cheers for any help
steph
Nov 7, 2009 at 5:35 AM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
have the car plugged into a diagnostic computer to locate the cause of the ABS fault .. your local dealer will be able to supply the radio code if you supply the VIN number (assuming it is the original radio)
Nov 26, 2009 at 6:14 AM
