1964 Ford Galaxie High Temp
1964 FORD GALAXIE
79,000 MILES • V8 • 2WD • AUTOMATIC
HEFTYHEPPY
I recently installed a 390 cu in motor in my car. This engine was rebuilt. When driving the temp runs around 200 deg. In slow traffic or going up hill it may go to 215 or a little higher. I nstalled a 195 thermostat. The radiator was cleaned and checked. A couple of people told me to install a lower thermostat? Will a exttra fan work? Any help will be most appreciated.
Apr 3, 2010 at 8:05 PM
FACTORYJACK
  • 4,159 POSTS
Is it equipped with a clutch type fan? Is this perhaps not operating properly. A lower operating thermostat should lower the temperature, unless you have a cooling system problem.
Apr 9, 2010 at 12:42 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Yes a lower thermostat will help assume engine is a 60's era ie. non pollution. If yes drop to 160 deg. a Hayden electric fan is great idea you can get rid of fan gain @15hp.
Let me know what happens
Sorry about delay
Thnaks for donate
Apr 9, 2010 at 2:28 PM
