2006 Ford Freestyle p1000
2006 FORD FREESTYLE
ISAIAH OYENIYI
Engine Mechanical problem
2006 Ford Freestyle 6 cyl All Wheel Drive Automatic
please how can i solve the trouble code p1000.my car lost acceleration.what can i do to solve this problem
Oct 16, 2010 at 11:31 PM
Usually a trouble code P1000 or manufacturers equivalent. We have listed several reasons for this condition.
Stuck Engine Thermostat - If the engine thermostat has stuck open it forces the engine coolant to stay at too low of a temperature causing the ECM/PCM to stay in open loop. This open loop creates a state of preprogrammed parameters were no diagnostic tests can be preformed. (ECM/PCM is constantly waiting for the engine to heat up to operating temperature for closed loop operation)
Shorted Oxygen Sensor/Coolant Sensor - The ECM/PCM relies on information from sensors to operated, if one of these sensors is severely shorted it can cause the ECM/PCM to stay in open loop, causing a code gathering incomplete trouble code
Shorted Fuel Injector - If a fuel injector short circuits it can cause the engine not to run by shorting the injector driver. If the car doesn't run and a code gathering incomplete trouble code like P1000 is present, it could be a fuel injector shorted. Unplug all injectors and try to rescan system
Oct 17, 2010 at 9:29 PM
