2002 Ford Focus overheating
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
RUBYLIN
Change the thermostat and cleanded out the engine cause it over heated and trew all water out from reservoir tank. But now is still heating up. The fans will only turn on when a/c is on. What could be the problems that the fans are not getting the signal to turn on to cool the car?
Aug 31, 2009 at 10:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
inspect cooling fan relay(s). if OK, suspect faulty engine coolant temp. (ECT) sensor.
Aug 31, 2009 at 10:11 AM
TESSALOVE
i have an 2001 focus and when that happened with my car i had to replace my sensors and it costed me like $600
Sep 8, 2009 at 4:04 PM
