ENGINE HAD MISFIRE CODE PO-302. I ERASED CODE AND IT CAME BACK. HAS NEW WIRES AND I LOOKED AT PLUGS. LOOK OK SO I SWAPED # 2 PLUG WITH # 4 AND CHECK ENGINE LITE OR CODE NEVER CAME BACK BUT MISS AT IDLE IS STILL THERE. CHECKED KV ON PLUG WIRES WITH ENGINE RUNNING AND THEY READ AS FOLLOWS #1 READ ABOUT 32KV AND #2&4 READ ABOUT 8KV. COULD WE HAVE A PC OR IGNITION COIL PROBLEM. ARE THE CYLS PAIRED ON THIS ENGINE. SEEM TO RUN FINE ON THE ROAD.
Feb 5, 2009 at 6:23 AM
