2001 Ford Focus leaking water from the block
2001 FORD FOCUS
BJREED1488
Engine Mechanical problem
2001 Ford Focus 4 cyl Two Wheel Drive Manual
my gauges never showed that my car had anything wrong but it started to die when i was stoping an then it started leaking water from the block as fast as i would pore it in.
May 24, 2009 at 2:14 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:05c990547a="bjreed1488"]Engine Mechanical problem
my gauges never showed that my car had anything wrong but it started to die when i was stoping an then it started leaking water from the block as fast as i would pore it in.[/quote:05c990547a]
Can you be more specific as to location other than block.
Front of engine
Passenger or driver side
Rear or engine etc.
May 24, 2009 at 2:19 PM
