my car died on me so i had it towed and replaced the fuel pump, started the car back up after fuel pump was fixed it started right up however tried to drive it and it started to putter and then died again. cant check fuel pressure dont have the proper tool, do you think it could be the fuel pressure sensor that is out now? and if so how can you tell if that is the problem?
Dec 9, 2009 at 11:27 AM
