2001 Ford Focus
STARRANN
  • 2001 FORD FOCUS
2001 Ford Focus
what is the torc specs on this car?
Saturday, December 13th, 2008 AT 4:05 PM
DAVE H
  • 13,383 POSTS
TORQUE SPECIFICATIONS (FOCUS)
Application. Ft. Lbs. (N.M)
A/C Compressor Mounting Bolt.18 (25)
Accessory Drive Bracket Bolt.35 (48
Camshaft Sprocket Bolt.77 (105)
Connecting Rod Cap Nut.28 (38
Crankshaft Pulley Bolt.89 (120)
Crankshaft Rear Seal Retainer Bolt.18 (25)
Cylinder Head Bolt (1)
Step 1.37 (50)
Step 2. Loosen 180 Degrees
Step 3.37 (50)
Step 4. Additional 90 Degrees
Step 5. Additional 90 Degrees
Exhaust Manifold Nuts.20 (27)
Flywheel Bolt.60 (82)
Generator Mounting Bolt.35 (48
Main Bearing Cap Bolt.73 (99)
Oil Pan Baffle Bolt.18 (25)
Oil Pan Bolt.18 (25)
Oil Pump-To-Block.10 (14)
Rocker Arm Bolt.18 (25)
Spark Plug.11 (15)
Timing Belt Tensioner Bolt.18 (25)
Transaxle-To-Engine Bolt.59 (80)
Upper Timing Belt Cover Bolt.35 (48
Water Pump Bolt.18 (25)
Wheel Lug Nut
2000.63 (85)
2001.94 (128
INCH Lbs. (N.M)
Camshaft Thrust Plate Bolt.89 (10)
Intake Manifold Bolt/Nut
Stage 1.89 (10)
Stage2. Additional 90 Degrees
Timing Belt Cover Bolt.89 (10)
Oil Pump Screen Cover & Tube Bolt.89 (10)
Valve Cover.80 (9)
(1)After step 1, loosen bolts 1/2 turn. Then perform all 3 steps. Tighten in sequence
Saturday, December 13th, 2008 AT 4:43 PM
Related General Content
