2000 Ford Focus Ignition
157,050 MILES • 4 CYL • FWD • AUTOMATIC
URLACHER54
I have a problem with my key not going all the way into the iginiton. The lights and horn and everything like that works but I can't get the key to go ALL the way in. It has happened once before but I jiggled the keys and it went in but now nothing. I was just wondering if it was an ignition problem or what else it could be.
Sep 24, 2009 at 2:17 AM
RENAUDTN
  • 636 POSTS
It sounds like a bad ignition cylinder. Focus are notorious for that. A lot of time people have trouble turning their key to start the car as well…you can try replacing the cylinder yourself if you’re mechanically inclined. If not I suggest you call a locksmith; chances are he fixed Focus ignitions before and knows the drill… literally. I would stay away from Ford dealers…they’re expensive and will simply put another crappy Ford ignition in there at a cost of around $400-500.
If you do some research online you’ll find a lot of websites with people having similar problems as yours.
Sep 24, 2009 at 6:38 AM
