2000 Ford Focus Engines chugs between shifting of gears
SMILER2729
  • 2000 FORD FOCUS
Transmission problem
2000 Ford Focus 4 cyl Manual 340000 miles
I don't know if it's a clutch problem (there's no chugging in reverse) or an engine/transmission problem.
Thursday, October 21st, 2010 AT 11:20 AM
SERVICE WRITER
  • 9,123 POSTS
So it does not chug when in gear? But just between them?
ORiginal clutch?
Thursday, October 21st, 2010 AT 5:47 PM
SMILER2729
It chugs when I shift gears and also when my speed slows while in gear (say 5th or 4th while cruising the highway).
The Check Engine light has been on since I got this car but when it chugs it will flash until the engine sort of 'catches' and stops chugging.
I've only had this car since March so I have to believe this isn't the original clutch.
Friday, October 22nd, 2010 AT 6:46 AM
SERVICE WRITER
  • 9,123 POSTS
Okay.
This sounds like you are having a rich condition and need to address the cel.
When the cel flashes, most often too much fuel is not being burned getting into the catalytic converter. This will detroy the converter iof it already hasn't. The chugging is misfiring.
Need to get this diagnosed or start troubleshooting by getting the codes from the pcm.
Friday, October 22nd, 2010 AT 7:21 AM
SMILER2729
Okay the "chugging" between gear shifting has ceased and the Check Engine Light is now flashing constantly. What is new is what sounds like a muffler problem and very bad gas mileage.
Could all these symptoms be a need for a new muffler?
Wednesday, October 27th, 2010 AT 7:16 AM
SERVICE WRITER
  • 9,123 POSTS
When the check engin llight flashes, most often too much fuel is not being burned getting into the catalytic converter. This will detroy the converter iof it already hasn't.
Converter is prolly shot. Need to find what codes are listed in the pcm.I expect a po30x misfire code and Po420 cat code
Wednesday, October 27th, 2010 AT 9:05 AM
