There can be many things causing the vibration you are experiencing.
If you have not done so, you really should visit a qualified tire shop or mechanic.
You could be looking at a tire problem (slipped belt, out of balance, uneven tire wear.)
You could also be looking at suspension problems such as shocks/struts, broken coil springs, etc.
If it is vibrating like you are in a washing machine, this may be a very serious issue.
SPONSORED LINKS
Monday, June 22nd, 2009 AT 11:28 PM
